56 f100 front shackle pin bushing removal
Anyone have any secrets to removing these little gems? Of course I saved the 8.50 when I ordered close to 930.00 in parts and shipping by not buying the MF bushing removal tool and now I have a garage full of parts and two stubborn bushings that I can't get to move...
JB
JB
JB, my 1956 F-250 is identical to your F-100 in the front. I am (glacially slowly) doing a ground-up restoration and took the springs and all spring hangers off the frame to get the frame back in good condition. That means I could set up the springs and hangers on one of my workbenches to remove the bushings.
Even with that advantage, I simply couldn't get all of them out without buggering them up. That isn't a problem for the removed bushings as they went into the metal recycling bin. It was clear to me, however, that I would make a mess of my nice new bushings if I tried to use the same techniques to install them.
If I knew I wouldn't need to press in or push out any other parts I would have spent the $9.50 plus shipping (https://midfifty.com/part.php?CAT_ID=385&SEL_ID=426) and been done with it. I knew, however, that I had at least six or more other items that would require a press for removal of old parts and installation of new ones. I built my own benchtop press and it's done all the work very well.
I think you realistically have three options. First, if you don't see yourself needing a general purpose press for other work on your truck (or other vehicles), spend the $14 or so and just be done with it. Second, if you are going to need a general press for other work, pick one up at Harbor Freight or your favorite tool supplier. Third, if you are eccentric like I am, build your own press and take care of business.
Good luck and know that you are not alone in having trouble with those little buggers.
George is right. I struggled with removing the bushings, so I went to Harbor Freight and got a 12 ton press. Suckers popped right out. Amazing the uses around the shop for the press. After I bought it I realized that I could of made one myself like George did. Buy or make one you won't regret it.
The press would be a great idea but I'd need about 10-12 of you guys to come over so we could get the frame positioned in the press! I ordered new springs so those bushings are already installed... I need just the two in the front spring hanger riveted to the frame.
Yesterday I had an impact socket that matched the diameter of the bushing but still fit inside the frame and was trying to beat it out but the only thing I accomplished was boogering up the end of the bushing...
Bravo
Bravo
stlouis55
05-21-2014 05:42 AM
proudfrog
1997-2006 Expedition & Navigator
02-13-2011 11:58 AM
proudfrog
02-13-2011 11:56 AM
Grubbworm
30
06-28-2010 01:48 PM
