Two Fords with two different RKE remotes
Hello FTE:
I have a '97 Expedition and last week purchased a '02 SD F250. They both have their own keyless entry remotes. I would like to use one remote for both vehicles. My 250's owners manual explains how to reprogram the remotes but there is no mention of reprogram the truck itself.
Is it possible to use one remote for both?
Thanks!
Mike
Thanks!
Mike
I only know of reprogramming the remotes - not sure about the "2 in one" idea though...
You could just keep the keys & remotes on seperate chains - it will cut down on how much gear you have to carry around with you (it will also cut down on the tap...tap...tap...tap.... of the keys/chain tapping the steering column.
XXL
XXL
What?? Sure you can program 2 trucks to 1 remote. The remote doesn't care what device receives the signal, as long as the device knows that signal is intended for it. I have done it, the only key is they both have to use the same remote. In 1999, Ford made a change to the remote system, resulting in a different remote. In your case, you probably have 2 different remotes, which won't interchange. Your 1997 Expedition uses a PATS I systems, while your 02 SD uses the PATS II system. That means different key blanks, different remotes, different methods of programming your key. If your Expedition happend to be 2 years newer, you would be good to go. If I am not mistaken, your Expedition remote has the words lock and unlock on the buttons, while the SD remote has picutres of a lock.
02bigrig
12-20-2006 11:01 PM
