Fuel Filter problem
I looked and it doesn't look like it is leaking from the filter. I do see a puddle of fuel right under the turbo and the leak definately started after I changed the filter. Now I smell diesel and can see the puddle.
Do you think I loosed anything when I unscrewed the fuel filter cap? What can I check to see, or tighten?
I am going to clean it as best as I can and see if I can see where it's leaking from. Maybe one of the lines going into the filter?
You may have the O-rings in the drain valve leaking.
It's a cheap, easy fix once you get the new rings.
See: Replacement O-rings for Diesel Engines
Pop
Pop
Get a flex mirror and a bendable stem, LED super bright light. ( got one at Harbor freight for cheap and now I cant stop bragging about it)
Fuel Filter
I'm not sure what you have going on there -- did you make sure all the old O-rings came out? The center one can stick on there if you're not looking for it. The cap O-ring goes on what I think is in a counter-intuitive way. The bevel looks like it goes the wrong way, but it seals.
Your fuel bleeder valve may be leaking. Easy quick fix. I picked up and I think is has 2 bolts on the side. Replaced and hadn't leaked for 3 years now! Knock on wood.
Yeah, I think I got all the orings out, can't remember now since it was few weekends ago. My new o-ring was way too big to use. Or at least I thought so.
Now that I think of it, I had a small fuel leak for a while now, never enough to drip, but enough to make a trail down the front of the tranny.
I'll check my drain o-rings since I also have a small puddle in the valley now, and diesel smell in the cab.
thanks for the tip about the mirror.
cajunbronco
06-16-2002 09:56 PM
