Starter bolts
Old 09-22-2009, 03:39 PM
61 uni's Avatar
61 uni
61 uni is offline
Starter bolts
I checked today and sure enough I'm missing one. Does the end of the bolt have to be turned down like the oem bolt? Is blue locktite good enough?
Old 09-22-2009, 08:05 PM
89LX306's Avatar
89LX306
89LX306 is offline
You might want to check and make sure the bolt hole is not stripped. Mine was.
Old 09-22-2009, 08:25 PM
61 uni's Avatar
61 uni
61 uni is offline
I'm gonna chase the threads with a tap before I put it in.
Old 09-22-2009, 10:37 PM
camodown's Avatar
camodown
camodown is offline
I had problems with my starter bolt backing out. So far the helicoil has worked great. No problems or backing out. What starter are you using?
Old 09-23-2009, 08:17 AM
61 uni's Avatar
61 uni
61 uni is offline
As far as I know it's stock. It grinded pretty bad monday and sure enough a bolt was missing. The threads has a lot of trash in it, so i'm guessing it's been gone for a while.
Old 09-23-2009, 08:21 AM
89LX306's Avatar
89LX306
89LX306 is offline
FWIW mine has backed out 3 times in 200k miles. I have cleaned them and used loctite each time.
Old 09-23-2009, 08:22 AM
61 uni's Avatar
61 uni
61 uni is offline
red or blue
Old 09-23-2009, 09:16 AM
89LX306's Avatar
89LX306
89LX306 is offline
Blue the first time, red this last time. Of course my threads my have given up when I snugged the bolt down the last time.
Old 09-23-2009, 10:36 AM
dcf4x4's Avatar
dcf4x4
dcf4x4 is offline
Is this all random occurrence?
I almost lost mine as well, a month ago. Upper bolt was missing, and had been for awhile, and the lower was half way out. The first time in 5 years and 2 starters. I changed the starter exactly a year ago.
Just wondering what would have caused this. I red locktighted the bolts and so far so good.
Old 09-23-2009, 07:10 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Its interesting, and it may just be coincidence, but all of you have 2002 trucks with the exception of dcf4x4 who has a 2000. However, he has replaced his starter and since locktite has been good to go.
Old 09-23-2009, 08:32 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
Mines an 03, I guess I need to get under there and make sure they are snug.
seajr1978
08-06-2012 06:47 PM
Cowman79
12-31-2011 09:45 AM
67nukeford
1997 - 2003 F150
10-23-2008 07:40 AM
parks911
Paint & Bodywork
21
04-08-2004 11:30 PM
AbadDriver
1978 - 1996 Big Bronco
07-08-2003 09:11 AM
Quick Reply: Starter bolts
