1978 - 1996 Big Bronco
Top mounting hardware
Old Jul 6, 2003 | 08:57 PM
AbadDriver's Avatar
AbadDriver
Well, i put my top back on(got too wet) but when I was bolting it down, i realized i had enough hardware for only 3 bolts. is that enough or should i pull the top back off to be safe. BTW what else could i use to bolt it down.
BTW again, the peices that i lost are the lil pieces of metal that the bolt bolt into.
Thx
Tim
Old Jul 7, 2003 | 11:26 AM
steve83's Avatar
steve83
Large washers would be better than nothing, but you can order those clips from Ford or Jeff's Bronco Graveyard.
Old Jul 7, 2003 | 12:22 PM
AlM's Avatar
AlM
yo,
Steve, I see that a few On-Line Ford Dealers/Parts suppliers are now listing the "nut", p/n n800925-s100
$0.71
but show it as for:
"Cab - Exterior trim - Step assy - Retainer
Inner - Regular cab Step assembly 1992 - 1996 ... "
http://www.cybrrpartspro.com/Chilton.../84920031L.gif
Geno makes em too; URL for Geno is in my web page under Parts
Old Jul 7, 2003 | 12:31 PM
steve83's Avatar
steve83
That image actually doesn't show what I was talking about. It's the clip that goes between the bolt head and the fiberglass that the screws/push rivets grab to hold the inside trim on to hide the bolt heads.
Old Jul 7, 2003 | 12:52 PM
steve83's Avatar
steve83
I just looked it up on the CD and the regular clips are #6 PN 29126 "Body Side Window Garnish Moulding Front Bracket" and the ones on the angle area are #10 PN 29070 "Body Side Window Garnish Moulding Bracket". I couldn't find an online source or price.
Old Jul 7, 2003 | 01:39 PM
AlM's Avatar
AlM
yo Steve,
Doesn't he want the other piece?
Old Jul 7, 2003 | 01:58 PM
steve83's Avatar
steve83
I dunno - maybe he DID mean the U-nuts. I figured he meant those clips because they're so easy to lose.
Old Jul 7, 2003 | 06:31 PM
AlM's Avatar
AlM
yo Steve,
I think he did mean the U nuts:
Geno - Bronco body extruded u nuts - these are the fasteners clipped to the body (inside, under the side window trim) they are called extruded u nuts or fold-over nuts - thanks to Chris B for the info!
http://www.geno-inc.org/English/Products/products.html
Here is the one you meant, thanks to Ken (I believe possibly it could be probably what you meant...maybe):
http://www.froggmann.com/Images/Tech/Top/TopRe016.jpg
Old Jul 7, 2003 | 09:55 PM
AbadDriver's Avatar
AbadDriver
from what i can see in the pictures i think its the "nut" that i lost. i have all the bolts but only 3 of the "nuts" i want like 3 more so when i do have the top on itll be nice and solid.
Tim
Old Jul 7, 2003 | 11:36 PM
steve83's Avatar
steve83
Every parts store I've been in has those in blister packs. Lowe's also sells them, but for like $3 ea.
Old Jul 8, 2003 | 09:11 AM
AbadDriver's Avatar
AbadDriver
Thx steve. Ill hve to get some today.
Tim
Aftrmidnite
1997 - 2003 F150
Apr 23, 2016 09:58 AM
SlikWillie
16
Jan 18, 2016 07:07 PM
joegeds
Jul 12, 2013 07:25 AM
1983F1503004x4
Mar 5, 2013 11:57 AM
