Brake Hose Failure
Brake Hose Failure
Had my rear break hose fail today. (frame to rear end). Hit up a few local auto part stores and settled on one that will be in at 0700 tomorrow (Saturday). I guess since they are 40 years old I should replace the steel lines too. I plan to buy a roll of brake line and a handful of fittings while borrowing the bending and double flair tool.
Do I need to be aware of anything that may not be obvious when running a new brake line and removing the old.. This is for the rear only this weekend, perhaps next weekend I will do the front as i don't want to have them go out on me all of a sudden..
1970 F100 2WD SB w/ 302 or 298 & C4 tranny.
Took the wheels and drums off to find a blown out wheel cylinder and break fluid everywhere all soaked up in the shoes.. So she gets new wheel cylinders and shoes in the rear too.
So as of today everything from the metering block back is new when it comes to the rear braking system.. expect for the drums.. I am afraid to look at the front although this has been a very simple repair thus far.
Well the hard lines from the metering block back needed to be replaced.. The flex hose / line junction would not separate so I had to cut it and then moved forward on the truck and had same issue. the passenger side on the rear end had a nice kink in it so that is being replaced and the driver side rear is only 20'' long so I am replacing it too.
Hope everyone had a great weekend..
Doing the front drums on my 64 now. The wheel cylinders were scary bad, and the shoes were installed backwards. Tried to disassemble the L/H cylinder to see how much crud was inside but it was gummed up. I don't think they were doing much. With new M/C, lines and hoses, shoes, drums and cylinders on one axle it will increase pressures elsewhere. In other words it may blow out another cylinder or hose or whatever.
Yeah, I figure they were probably ready to be changed out. In 1980.
I bought a pair of those goofy looking brake spring pliers at NAPA along with the rest of the stuff. They had two different kinds. I bought the cheaper pair, for almost six bucks.
I had figured the socket looking thing on the end was for those pin springs. Nope.That's to remove the return springs, I done watched me a genuine YouTube video that shows how to use them.
I don't know what the plier part are for, but the notched handle end works slick as hell for installing new return springs. A screwdriver with a notch will work too, just wanted to try them out.
Brake Spring Tool! - YouTube
I was going to ask about that spring. The Shop Manual shows a picture of it, tho leaves it unnamed, but describes an "assist" spring in the text. Spring kits don't include it afaik either. But if one shows up, I'll be ready now!!
edit: I think you are referencing the star adjuster spring prior to self adjusters, it just installs across the shoes?
dwstenersen
01-09-2017 01:46 PM
