1978 - 1996 Big Bronco
Brake Hose Fitting Sizes
Old May 16, 2004 | 12:30 AM
PetrozP's Avatar
PetrozP
I am putting in some new brake line and a new rear hose. The hose has two different size holes....The hold that goes to the passenger side line matches the size of the fitting that came witht he new 3/16 brake line...but the other side has a hole that is larger. I think it was the same way with the old brake hose too...but i dont have the old fittings or hose. Is this right and what size fitting is needed??
Old May 16, 2004 | 03:21 AM
SproutW's Avatar
SproutW
You are correct on the larger hole. I ended up cutting the old fitting off my old line and reused it on my new line. I cannot remember the size fitting you will need but your local parts store may have the fitting. I always buy a couple different sized fittings to make sure I don't have to make a return trip. Hope this helps.
GoldCo
Oct 27, 2016 04:29 PM
Anthony Polsinelli
Apr 14, 2016 07:13 PM
cityjack
13
Apr 7, 2016 08:45 PM
Greg5OH
Nov 12, 2015 07:11 PM
Gettysburg150
Mar 11, 2015 06:56 AM
