Hello From Iowa. Need D60 help
Hello. I just bought a Dana 60 Rear Axle last night. Tag says 4.10s and it seems to be posi. Its said to be from a 1975 F250 Highboy(I know Highboy is a aftermarket nick name) Im looking for a place to decode the BOM
C91A-DC
603092-2
Any help would be great.
C91A-DC
603092-2
According to your numbers its a dana 60 rear powr lok 4.10. From a 1970 f250 2wd truck. 1 5/16" shaft with 16 spline,33 5/8 axle length. Decent axle but keep horsepwr down because you will shear splines off. I have one of these axles here at house. If you use close to stock tires good to go.
Welcome to FTE
Ford ID Number: C9TA-DC // Dana ID Number: 603092-2
This rear axle was originally installed in a 1969 F250.
1969 F250 Dana 60 / 4.10-1 / Limited Slip / 16 Spline Axle Shafts / 5300 lb. Rear Axle Capacity / Rear Axle Parts List #94.
If this rear axle was from a 1970 thru 1974...it would have different FoMoCo ID numbers: DOTA-AH 1970 / D1TA-SA 1971/72 / D3TA-JA 1973 / D4TA-GDA 1974.
And...if this rear axle was from a 1975, not only would the ID number be different (D5TA-JUB), but the axle shafts would have 30 splines.
Info sources: 1964/72 & 1973/79 Ford Truck Parts Catalogs.
Well there is only 1 way to find out for sure. To pull one axle can I just unbolt everything from the flange and pull it out? I have no experience with these axles. My plan was to narrow this to put under a steet car with about 550 hp.
If this wont work. Can it be switched over to 30spline. If so what parts do I need to look for?
DoubleChicken
38
12-25-2016 10:52 AM
Obowersox26
09-17-2015 06:55 AM
zenmaster
03-09-2009 12:12 AM
ozzy460
09-11-2004 07:06 PM
