Highboy Dana 60 conversion help
Old Sep 16, 2015 | 08:34 PM
Obowersox26's Avatar
Obowersox26
Hello, I have a 1976 f250 highboy with a king pin dana 60 with cross over steering. I just purchased a 2 inch lift. What is the most right way to correct the steering? Dropped pitman? 2 inch steering arm spacer? Thanks
Old Sep 16, 2015 | 08:56 PM
PA74F250's Avatar
PA74F250
A 2" lift might not even really drive different than stock. I have a 4" lift and went with crossover steering for my D60. The bar is like straight across. If you were to do anything a drop pitman arm would be the easiest and probably the safest.
Old Sep 16, 2015 | 10:20 PM
co425's Avatar
co425
I have a 2" lift with my Dana 60 front, crossover steering. My tie rod end is within a 1/2" of the bottom of the frame. At the most a drop pitman may be required but I doubt it.
Old Sep 17, 2015 | 06:31 AM
Obowersox26
Ya the pitman arm sounds like a good idea , we're would you find one? I have 79 f350 steering componets on mine
Old Sep 17, 2015 | 06:55 AM
PA74F250's Avatar
PA74F250
You may find something cheaper I don't know:
http://shop.broncograveyard.com/mobile/Drop-Pitman-Arm-F250-F350/productinfo/22826/
ktm4012
Mar 10, 2016 08:14 AM
mizsignals
52
Dec 17, 2010 03:24 PM
BigBody
16
Jul 27, 2009 01:34 AM
crazyredneckanyhow
Offroad & 4x4
Jul 28, 2007 10:56 AM
78xltcrewcab
Mar 4, 2007 05:18 AM
