A question for Bill...........
Bill, as the resident parts guru have you ever seen one of these?
I replaced the 361 FT engine in my 1975 F-350 Tow Truck with an early (66) 352.
This is the original bell housing from the 75. I've never seen a FE bellhousing with the "ears" for mounting like this one has. I checked it with my sons 61 Uni and it fits the crossmember for the 61 perfict. If these arn't to rare they would be a good way to put an FE in an early ford that used a Y-block. Just wondered..........................
Notice the FoMoCo ID number on the right lower side of the bell housing.
I can make out C4TA-7505-
But what's the following letter...C or G?
I need to know, because there are two different bellhousings for two different applications.
Ford ID number: C4TA-7505-C = Ford part number: C4TZ-7505-F
Ford ID number: C4TA-7505-G = Ford part number: C4TZ-7505-D
C4TZ7505D =
1964/69 (B/C/N/T) F500/750 330/361 New Process 435 4 Speed Manual Transmission.
1964/69 (B/C/N) F500/800 330/361/391 Clark 5 Speed Model 250.
1970/78 (B/C/CT/LN500/800) F500/750 330/361/391 Warner T-19 4 speed / New Process 435 / Clark 280 5 speed.
1965 F100/250 4WD, 1965/66 F350, 1966 F250 4WD use different bell housings than 1965/66 F100/250 2WD, 1966 F100 4WD, 1967/76 F100/350.
Engines in these 4WD's, F350's use the three point mounting system, as did all 1961/64's and 1964/78 FT engines.
1973/78 F350's made exclusively for U-haul have the 330 2V M/D FT engine, the only F350's to use it.
What is that hump where the starter goes into for? Did the FT's use the same starter as FE's?
