223 distributor questions
Old Sep 11, 2012 | 11:42 AM
boggerted's Avatar
boggerted
My 62 Ford F500 is almost ready to be put back in to service. I swapped out the original 223 due to excessive wear and swapped in a 223 from a 56 f100. I tried to start the donor engine on a stand but was only able to get it to backfire out the intake. I suspect the distributor was installed wrong. How does one go about lining up the dizzy gear correctly so its timed right? Also, i am missing the hold down clamp that keeps the dizzy tight. Where would I be able to get one of these? Neither the original nor the donor engine seems to have one. Also, what is the correct points gap for these? Thanks for the help!
Old Sep 11, 2012 | 03:58 PM
f5fordgirl's Avatar
f5fordgirl
Points gap is 016, to time it, pull #1 plug, with your thumb over the plug hole, turn the engine the correct way, till you feel compression. Turn it more till the timing marks line up, you are on tdc #1. Pull the dist, turn the rotor till it points at the 1 on the cap, put it back in, make sure it still points in the direction, in stall cap, rotor, and any wires you unhooked, and if everthing else is ok, you're ready to go. Firing order is 1 5 3 6 2 4.
Old Sep 11, 2012 | 08:24 PM
Buzz44's Avatar
Buzz44
My son and I are messing with getting a 223 running in a 64 right now. If memory serves there is no hold down on the distributor. 2 bolts with thick washers is all I seem to recall.
Old Sep 12, 2012 | 09:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Better look around the shop, you're missing something.
C3AZ-12270-A (replaced FAA-12270-A & D1FZ-12270-A) .. Clamp-Dizzy to Cylinder Block (Motorcraft DZ-410) / Available from Ford.
1952/53 215 I-6 / 1954/64 223 I-6 / 1960/83 144/170/200/250 I-6's / 1961/64 262 I-6 / 1971/73 Pinto 98/122 I-4's / 1965/74 240/300 I-6's / 1975/96 300 I-6.
MSRP: $9.29 // FTE sponsor horizonpartsguy.com (aka partsguyed.com) price: $6.13 / Horizon Ford in Tukwila WA
Old Sep 12, 2012 | 09:03 PM
Buzz44's Avatar
Buzz44
Thanks Bill Ill put my readers on next time I take a look down there it may be buried in the grease. Whatever is there is holding the dizz in place when tightend up.
Old Sep 13, 2012 | 07:37 AM
boggerted's Avatar
boggerted
Numberdummy, thank you very much for your research! So, if I read the description right, a dizzy clamp from a 87-96 300 I6 will work?
gwcrutch
Jul 31, 2018 11:36 AM
duhrbroc
May 31, 2009 11:17 AM
ottawaguy
Jan 5, 2008 03:59 PM
tjm73
Jun 14, 2005 02:08 PM
teachcool
Jan 4, 2003 06:41 PM
