VIN expert needed
03-12-2009, 05:48 PM
on
VIN expert needed
Need help with VIN #f15jkx81540. also what axle/gears is 13j?
thanks
03-12-2009, 06:13 PM
F15JKX81540
F15 - F150 2WD
J - 460
K - Kansas City assembly plant
X81540 - 1977
13J - Ford 9" 2.75 open rear end.
03-13-2009, 09:29 AM
on
Thank you,sir. Where did you find gear info? I have a 78 t-bird with axle code 1. Would you happen to know this one too?
again, thanks
03-13-2009, 09:54 AM
Ford's Parts catalog.
Nope - I don't know anything about Thunderbirds at all.
03-13-2009, 10:21 AM
on
i can help you with the axle code i think
ID tag......Ratio...... Ring Gear.... Differential
........................Diameter (in).... type
WFA-AA..... 3.00:1..........9............ T4
WFA-AH..... 3.00:1..........9............ T4
WFA-AL..... 2.75:1..........9............ T4
any if those codes right,,, if not what is your code?
03-13-2009, 06:37 PM
on
OK, here goes.
WEB-BF 8CE
2 50 9 800A
This came off the tag. 2.50 to 1 ratio?
03-13-2009, 08:32 PM
Yep. It's a 9" rear end with an open 2.50 ratio.
03-14-2009, 05:07 AM
WEB-BF: 1977/78 Thunderbird/LTD II/Ranchero/Cougar use before 6/1/1978 = Ford 9" / 2.50-1 / non Limited Slip / 28 spline axle shafts.
8CE: Assembled the 5th week (E) of March (C) 1978 (8).
(WEB-BF used after 6/1/1978 is 2.47-1)
03-14-2009, 08:16 AM
on
thanks alot guys. 2.50 gears, maybe one reasond a hundai spanked me?
xxox
08-21-2019 02:24 PM
Itsme7
01-03-2011 09:22 PM
Crazydan
02-19-2006 11:16 PM
Rick_Ford
12-26-2002 12:05 AM
cams69
03-03-2001 06:51 PM
