need VIN decoded
Old Dec 20, 2002 | 10:42 AM
Rick_Ford's Avatar
Rick_Ford
need VIN decoded
Old Dec 23, 2002 | 07:55 PM
ford_nut's Avatar
ford_nut
need VIN decoded
HI folks
today I was given an 85 ford F250 crewcab 2wd for free. It is rough and it neeeds some work. Normally I am partial to 66-76 fords but hey, it was FREE. can someone help in decoding this VIN? I dont know anything about the fords from 77-up! here is the #
prefix 3
1FTHX 25Y5F KA844 21
thanks again
~~NUT~~
Old Dec 23, 2002 | 10:57 PM
steve83's Avatar
steve83
need VIN decoded
1FTHX25Y5FKA84421
1FT is US Ford Truck
H is the brake/GVWR 9-10,000lb
X says it's an extended cab (2-door), not a crew cab (4-door)
25 is F-250
Y is the 300ci straight 6 engine
5 is the VIN check digit
F is 1985
K is the Kansas City, MO, plant
& the rest is the serial number
How 'bout posting the door sticker codes?
Old Dec 25, 2002 | 11:13 AM
ford_nut's Avatar
ford_nut
need VIN decoded
steve
i had a chance to view the door codes and i saw tranny code A
and rear axle code of 45
what do i have here?
Old Dec 25, 2002 | 12:49 PM
brown 4x4's Avatar
brown 4x4
need VIN decoded
Tranny code A is the NP435 4 speed manual.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old Dec 25, 2002 | 08:37 PM
brown 4x4's Avatar
brown 4x4
need VIN decoded
And 45 is a Dana axle, 7400#, 4.10 ratio.
Old Dec 25, 2002 | 09:17 PM
ford_nut's Avatar
ford_nut
need VIN decoded
OK
now i know that i might be a pain in the *ss LOL but what kind of dana axle? that rating seems kind of high. what is that rating vs. a dana 60? the reason i ask is because the guy that gave it to me said that it is a factory 1 ton axle and i thought that he was pulling my leg. ford put a 1 ton axle in a 3/4 ton truck? something isnt right :-X23 thanks again!
Old Dec 26, 2002 | 12:05 AM
82F100SWB's Avatar
82F100SWB
need VIN decoded
It's a F250HD, one ton chassis with the exception of the front axle, frame is identical, rear axles are too.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
