new valve cover gasket
we hope that we didn't tighten it down too much.
73CaliF100, that's exactly what we did.
Ranger76, we ordered the gasket from NAPA and a cork one is what came in. we put it on and dad says if it leaks then we're gonna throw it in the trash and get a rubber one. he said the cork ones never worked good at all on his Peterbilt.
I have had no problems with cork gaskets...in fact, I prefer them.
The problem is not the material...it's the installation. Many times the gasket gets misaligned, the bolts are over-tightened, the cover itself has gotten bent, or the bolts loosen, allow oil to seep past the gasket, at which point it never seals well again.
Here's what has worked flawlessly for me:
1. throw away the stupid bolts and put some studs in. If the bolts have equalizing tabs on them, keep those.
2. make sure BOTH mating surfaces are CLEAN and DRY.
3. on a clean piece of wax paper, coat the gasket heavily on both sides with high tack Spray-A-Gasket (NAPA #765-1224), letting each side sit for at least 5 minutes.
4. install the gasket over the studs, lining it up evenly and seating it with as little pressure as possible.
5. install the valve cover and secure it to the head with ny-loc nuts on the studs. Tighten down 1/8 turn past the point that the nuts begin to press down on the cover, working in a circular pattern from end to end. Direction does not matter here.
6. let it sit overnight about 12 hours, then again in a circular pattern, tighten to the point THAT YOU ARE COMFORTABLE WITH.
I know it seems time consuming, but for me it's been worth it. I did this in my van five years ago and in my '62 IH eight years ago. Not one of them has leaked a drop from the valve cover(s) since, and I spent about 2 hours on each vehicle because I had to install the studs.
I think that folks just tend to be a bit more careless with a $5 cork gasket than a $20-$30 rubber one. If you do it right, you should never have to take it off and put it back on again.
Now where's my $.98 change?!
I put a cork gasket on my 77 300 I6 I got from Napa. The old one was cork also, and just fell apart when I took the valve cover off. I did the cross tightening which worked well, but I did have to go over them and snug them up after it ran a bit and heated up the cork. But it never leaked a drop, or aleast so far.
I know cork is old school, but it an old dent side and it kinda fits with it.
PS: I don't want any change back.
on
1 Post
The problem I always have with them is, straight out of the box they are already bent or crooked and I purchase the fel-pro brand, and when I go to put them on the valve covers, they never want to stay in place, even with putting the tabs in the grooves to hold them. The rubber ones are reinforced with a piece of metal that makes them hold their shape. The cork ones are fine and they do work (sometimes), but I would only put them on a beater, my truck may look like a beater, but its not. I got a modded 460 in it and it deserves the best parts only.
