Competition Diesel racing, sleds, dynos, power tuning and max performance.
Burnout???
Old 11-09-2007, 09:57 PM
FordGuy0131's Avatar
FordGuy0131
FordGuy0131 is offline
Burnout???
Hey guys,
How do you do a successful burnout with the 6.0 PSD automatic?
Thanks
Old 11-09-2007, 10:23 PM
LaxPlaya21's Avatar
LaxPlaya21
LaxPlaya21 is offline
hold the brake and give it gas... be ready for a one wheel smoke show!
Old 11-10-2007, 10:02 PM
meanv10's Avatar
meanv10
meanv10 is offline
be careful i did a one wheel burn out. and it welded the spider gears together. had to have the rear end rebuilt. This happened because when one wheel is spinning and the other isn't the spider gears are doing x2 the wheel speed so when it gets up to 80 the spider gears are doing 160 and at that speed it will through the oil off the gears. causing them to heat up.
Old 11-10-2007, 10:07 PM
88FordF-150's Avatar
88FordF-150
88FordF-150 is offline
Hold on the brake give it a little fuel, let the turbo build up a little then hammer it while still holding the brake. I dont suggest doing this all the time, and im sure you know the reasons lol.
Old 11-11-2007, 12:36 AM
FordGuy0131
thanks guys!!
Old 11-12-2008, 12:48 PM
80F100man's Avatar
80F100man
80F100man is offline
Much easier to just let it rain, then do your burnout because the pavement is wet, won't damage as much, don't need brake, etc.
Old 11-23-2008, 08:32 PM
BigBlack6L's Avatar
BigBlack6L
BigBlack6L is offline
I've got 3.73s and limited slip. I like to hold the brake hard, bring the rpms up to about 2000, then let off the brake and drop the hammer. It usually spins both tires and its REALLY cool!!
Old 11-25-2008, 09:08 PM
Power Smoker's Avatar
Power Smoker
Power Smoker is offline
It's all about balance between brake pressure and throttle as seen in the last 30 seconds of this video:
YouTube - BullyDog Dog Days 2008
Old 11-25-2008, 11:44 PM
FordGuy0131
Nice Burnout...you live true to your name
Old 11-26-2008, 03:20 PM
Dustball8504's Avatar
Dustball8504
Dustball8504 is offline
Power Smoker....your truck is amazing, very nice job on it!!!
Old 02-13-2009, 10:12 PM
william_04_x's Avatar
william_04_x
william_04_x is online now
down to the treads...nice...
Thoroughbred Diesel
General Diesel Discussion
10-20-2016 11:23 AM
DerekShiekhi
1978 - 1996 Big Bronco
10-04-2016 03:39 PM
ChrisAbbottExpy
1997-2006 Expedition & Navigator
03-08-2016 03:50 AM
remhaust
6.7L Power Stroke Diesel
13
01-08-2013 09:11 AM
tjthegreat
40
03-09-2008 11:01 PM
Quick Reply: Burnout???
