tekonsha voyager not working
Old 01-06-2009, 09:11 AM
DrFord's Avatar
DrFord
DrFord is offline
Question tekonsha voyager not working
Ok I recently bought a 2002 f-250 and it came with a Tekonsha voyager brake control. I tried hooking it up to my boat and I get nothing. I hook the boat up to my dad's truck and the brakes work fine so....
Does anybody know anything about this controller? how can I test it? I looked at the wiring instructions and it is wired properly and all wired sem to have power. however I do not get a green light on the box when I hook up the trailer, nor do I get a red one when I manually apply the brake slider.
All the lights work, just not the brakes.
is there any test I can do on the plug to check for wiring problems or a way to check if the box is bad?
Thanks
Old 01-06-2009, 10:14 AM
Gman22Expy's Avatar
Gman22Expy
Gman22Expy is offline
If there is power to the Voyager and it is still not functioning, my first reaction is the unit is NFG. For the cost of a new one it is not worth fixing. If looking new, skip the Voyager and go to either the Prodigy or P3, much better units and technology for only a few more bucks.
Old 01-06-2009, 05:42 PM
elee3's Avatar
elee3
elee3 is offline
Call Tekonsha. They have great customer service.
Old 01-06-2009, 06:26 PM
johnny567's Avatar
johnny567
johnny567 is offline
You can put A test light (the kind with A real bulb) on the brake wire at the plug & this should cause the green light to come on, slide manual lever it should go to red & the test light will get brighter. are you sure your boat trailer doesnt have surge brakes? most do, if so the controller wont do anything.
Old 01-06-2009, 07:35 PM
DrFord's Avatar
DrFord
DrFord is offline
Cool I will try that with the bulb. I assume you put one lead on the brake pin and ground the other?
Yea the boat has electric brakes, I put them on there myself after the surge brakes locked up and burnt a bearing out. GRRRR!!!!!
Old 01-06-2009, 08:42 PM
quaddriver's Avatar
quaddriver
quaddriver is offline
does this boat trailer have electric brakes?
Old 01-07-2009, 09:50 AM
johnny567's Avatar
johnny567
[quote=DrFord;6977131]Cool I will try that with the bulb. I assume you put one lead on the brake pin and ground the other? quote]
Yeah do that , make sure to get a good ground on the vehicle, & if it doesnt light up, I would go to the brake wire coming out of the voyager & try it there as well to see if its in the wire going back.
SkySkiJason
17
06-12-2017 07:22 PM
M@ts
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-14-2015 06:46 AM
bashby
11-08-2011 01:00 PM
tecahely683
01-26-2004 09:51 AM
GeneStoner
05-05-2003 06:39 PM
Quick Reply: tekonsha voyager not working
