1968 F250 Kill switch
do you use a mechanical fuel pump or an electric one? i have an electric one and have a switch in that power line, so the person might make it a block or so but that is about it. also i can turn the fuel tank selector switch to "off" and unless the person knows its there, they will not make it far.
A kill switch only gives minimal protection against those who would "pop" the tumbler on your ignition switch. A wire with clips from the battery to the coil/screwdriver at the solenoid and off they go, for a little while at least. Anyone who has even a little knowledge will take another wire with clips from the battery to the alternator and go as far as they want!! For better protection, pop the distributor cap and remove the rotor or use a piece of vacuum hose to make a fake coil wire. I know those things aren't as easy as flipping a switch, but I haven't been able to come up with any fool proof theft deterrent for these old Fords. I also have a 68 Mustang that I do NOT want to be stolen?!?!
Gene
Gene
Gene
Gene
Gene
Gene
