What Is My Towing Capacity
I AM WANTING TO PURCHASE A TOY HAULER 5TH WHEEL TRAILER. I HAVE AN 06 CREW CAB 2 NON DUALLY 6.0 PSD. MY TRUCK IS NOT A 4WD. I HAVE THE FORD FACTORY TOWING PACKAGE AND 3.73 REAR GEARS AUTO TRANS. IN THE EXPERIENCE OF YOU FOLKS - WHAT IS THE LARGEST TOY HAULER I CAN SAFELY TOW. MY BIKE WEIGHS IN AT 850 LBS. I TRAVEL ALONE SO I WOULD HAVE MINIMUM OF CLOTHES AND PERSONAL ITEMS ABOARD.
THANKS.
KEN BAILEY
Most 5th wheel Toy Haulers are gonna be a lot heavier than 12K lbs, especially loaded with your toy(s) , gear, fluids, and all the normal camping stuff inside.
Let us know what models you are considering, it may help to see what your mind set is.
I do know my cousin bought a 30' 5th wheel "normal" camper that supposedly weighed around 10k lbs. He traded his 05 F-250 CC LB for an 07 F-350 DRW CC LB within 2 months of buying the camper. Told me it was the best decision he ever made and the difference in stabilty alone was dramatic.
Changing your gears won't help. You have the power, your restriction will be the amount of weight you can carry on the rear axle. If I recall on the F250 the max weight on the rear axle is 6,000 lbs and on the F350 it is 7,100 lbs. That is why I went from the F250 to a F350. I was always borderline on the rear axle when I put it on a weigh scale. If you look at the specifications the two trucks are rated for the same overall weight when towing. It is just with the F250 you are restricted on how much of that weight rests on the truck.
F-250/350 CC SRW 2WD 6.0L TD 15,900c. This is the max 5th wheel tow capacity for an automatic transmission, from the Trailer Life towing guides. Here's the link to all the guides.
Trailer Life Magazine: America's Number One RV Magazine
