1978 - 1996 Big Bronco
Shims for rear end angle
Old Mar 2, 2016 | 11:52 AM
Billy Bailey's Avatar
Billy Bailey
I have a 96 bronco with a 7 in lift what degree shim should I go with?
Old Mar 2, 2016 | 03:12 PM
Kemicalburns's Avatar
Kemicalburns
are you running the stock wedge in there now? you may have to try a 2*, 4*, 6*. have you had your rear driveshaft lengthened yet?
Old Mar 2, 2016 | 03:13 PM
Billy Bailey
Looks like stoke wedges, and the driveshaft seems to fit fine
Old Mar 2, 2016 | 03:54 PM
Kemicalburns
the rear pinion should be about 12* if i recall. if your running the stock wedges than you shouldnt need a shim.
Old Mar 2, 2016 | 03:56 PM
Billy Bailey
The rear end is setting dead flat I'm assuming no wedges at all
Old Mar 3, 2016 | 11:09 AM
Kemicalburns
then you are probably fine, as you accelerate it will rotate up a little which is ok.
1977ford05
May 25, 2008 09:34 AM
51panhead0
Mar 6, 2007 04:42 PM
greybullit
Offroad & 4x4
Feb 17, 2006 03:56 PM
duback66
24
May 3, 2004 08:37 PM
The Tree
Nov 20, 2002 10:35 PM
