no shifting no brake lights
My friends 1997 F250 7.3 auto trans stopped working the other day. The truck will not shift into gear and the brake lights won't work. The fuse for the brake lights keeps blowing. We pulled the trailer harness and plugged it back in replaced the fuse. Brake lights do not work and fuse blows.
I will find out tonight which fuse blows. And yes, the fuse blows when you apply the brakes. I think the first think to do it figure out why the fuse blows with runs the break lights. This will help solve the no shifting at start issue.
Could it be the shift relay needing the brake lights on to shift.
Fuse #13 is probably the one blowing. It controls the Hazzard Flasher, Truck brake lights, Trailer brake lights and Shift interlock solenoid. Something is causing the fuse to blow for sure. I've had the trailer connector (male end, one attached to vehicle) wires come loose inside and short out.
The is a solenoid that keeps the truck in park unless the brake lights are on. If the brake lights don't work the truck doesn't come out of park.
There is a work around. Before starting the engine turn the key to the first click. Now move the shifter to N. Start the truck. You're fine until the next time you put it in park. But be careful, your brake lights will not be working!
not sure if its the same problem but...
I kept blowing the upper left fuse (#4 I think it is) when I was making the trip back from florida...my taillights, trailer lights, dash lights all went out....But turn signals, and flashers still worked.
It only happened to me when I had my trailer hooked up.. I guess there was a short somewhere n the trailer wiring...after I re-did the ground, they worked flawlessly
EricNCSU1204
01-04-2013 09:38 PM
DemonRace6
07-27-2011 09:24 AM
Thudpucker
Electrical Systems/Wiring
09-29-2006 02:53 PM
