front axle nut torque specs?
Old 09-27-2008, 01:42 PM
cwa11is's Avatar
cwa11is
cwa11is is offline
I have a 2006 2wd f-150. The right front wheel bearing went out and I just replaced the rotor assembly. Since it has the sealed bearings pressed into the rotor and upon removal I realized that the nut was much much tighter than I thought it should be, I want to know the correct torque setting for putting it back on. The part is not cheap and the Ford dealership won't tell me. Does any one here know or have a manual?
Thanks,
Chris
Old 09-27-2008, 03:14 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Old 09-27-2008, 03:20 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
crap, that is for a 4wd...sorry, don't have the 2wd version
Old 09-27-2008, 03:50 PM
cwa11is's Avatar
cwa11is
cwa11is is offline
Oh well, I appreciated your response. I'm really becoming irritated with the latest developments in technology. Maybe I'm just getting old.
Thanks again,
Chris
Old 09-27-2008, 09:42 PM
FordTechnician's Avatar
FordTechnician
FordTechnician is offline
It is pretty high for a 2wd.
Installation
  1. Position the brake disc on the spindle.
  1. NOTE: Tighten the spindle nut to the specified torque. Rotate the disc counterclockwise 5 rotations and then recheck the torque.
    Install a new spindle nut.
    • Tighten to 400 Nm (295 lb-ft).
  1. Install the spindle nut retainer and a new cotter pin.
  1. Position the brake caliper and anchor plate assembly and install 2 new bolts.
    • Tighten to 200 Nm (148 lb-ft).
  1. Install the wheel and tire. For additional information, refer to Section 204-04.
Old 09-28-2008, 05:29 AM
svt2205's Avatar
svt2205
svt2205 is offline
You're not re-using the spindle nut, are you? It's a one use item.
Old 02-15-2020, 02:49 PM
John Nix's Avatar
John Nix
John Nix is offline
2012 F-150 XLT 4 by 4 front wheel bearing torque specs
I am currently working on my mother-in-law's truck it is a 2012 F-150 XLT 4 x 4 and the front passenger hub is being replaced, I need to know the correct torque specs in inch pounds for the 17 mm spindle nut.
Old 02-15-2020, 03:21 PM
redfishtd's Avatar
redfishtd
redfishtd is offline
2wd is quite high for spindle nut . Nut One time use only , 295 foot pounds . I have a 300 pound wrench but there is a way to do it by using the length of the bar you are using . It is very important to get it close .
Threads are stretched to yield point if nut fails your wheel could come off .
jayro88
06-12-2016 05:13 PM
F-WhiteThunder
01-05-2016 11:30 AM
Chicken Hawk
2004 - 2008 F150
12-19-2015 06:01 PM
zzrich
04-11-2010 03:27 PM
FlyinFord
1999 to 2016 Super Duty
10-23-2009 08:23 PM
Quick Reply: front axle nut torque specs?
