front axle nut torque specs?
I have a 2006 2wd f-150. The right front wheel bearing went out and I just replaced the rotor assembly. Since it has the sealed bearings pressed into the rotor and upon removal I realized that the nut was much much tighter than I thought it should be, I want to know the correct torque setting for putting it back on. The part is not cheap and the Ford dealership won't tell me. Does any one here know or have a manual?
Thanks, Chris |
1 Attachment(s)
crap, that is for a 4wd...sorry, don't have the 2wd version
Oh well, I appreciated your response. I'm really becoming irritated with the latest developments in technology. Maybe I'm just getting old.
Thanks again, Chris |
It is pretty high for a 2wd.
Installation
You're not re-using the spindle nut, are you? It's a one use item.
2012 F-150 XLT 4 by 4 front wheel bearing torque specs
I am currently working on my mother-in-law's truck it is a 2012 F-150 XLT 4 x 4 and the front passenger hub is being replaced, I need to know the correct torque specs in inch pounds for the 17 mm spindle nut.
2wd is quite high for spindle nut . Nut One time use only , 295 foot pounds . I have a 300 pound wrench but there is a way to do it by using the length of the bar you are using . It is very important to get it close .
Threads are stretched to yield point if nut fails your wheel could come off . |
