Offroad & 4x4
Dana 44 trac loc question?
Old 04-18-2002, 07:03 PM
marriedguy1's Avatar
marriedguy1
marriedguy1 is offline
I have a chance to get a dana 44 trac loc posi unit from a guy for pretty cheap and was wondering if it fits the TTB front end on a 94 Bronco/F150. This unit came out of a straight axle Jeep. It is 30 splines just like the TTB. Any help will be appreciated.
Old 04-18-2002, 08:46 PM
orange peel's Avatar
orange peel
orange peel is offline
as long as its a d44 i dont see why it wouldnt. but dont go buyin it just cause i said that, but to me it would be the same.
Old 04-21-2002, 11:59 PM
DirtySideDown's Avatar
DirtySideDown
DirtySideDown is offline
If your TTB, what ever that is, is a Dana 44 it will fit. May have to change side gears, most likely not.
Old 04-22-2002, 12:08 AM
DirtySideDown
One more thing, you need to be sure that the gear ratio's of both units are the same or at least of the same range. The 44 use one carrier or gear ratios from 3.73 an up ie 4.10, 4.27 4.88 ect, another below 3.73, ie 3.54 3.08
Old 04-22-2002, 08:20 PM
marriedguy1
Thanks for the help guys. I am going to pick up the unit this weekend and install it in a couple of weeks. Thanks again.
Old 07-31-2002, 11:42 AM
95xltmud's Avatar
95xltmud
95xltmud is offline
Did you eventually get that D44 trac loc from the jeep and put it in your truck? I am about to do the same thing and i want to be sure it will work out. The only thing that makes me wonder is that since the ford uses the dana 44 as a front axle it uses reverse rotation gears, and i just wasnt sure if the carriers were different between them too. I was looking at new ones and i se separate ones listed for standard and reverse rotation, so it leads me to believe that a trac loc from a jeep may not be interchangeable. I was just wondering if you were able to do it. thanks.
-john
Old 07-31-2002, 01:13 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
The carriers are the same, I read from another post.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Old 08-04-2002, 10:54 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
bad news....its not going to fit. the short stub axle on the passanger side uses a c clip to retain itself. a jeep trac loc won't have the indent milled into the side gears for the c clip. you could change the side gears, but that adds up rather quickly. The side gears are fairly expensive.
Ryan
Old 08-04-2002, 10:58 PM
95xltmud's Avatar
95xltmud
95xltmud is offline
Thanks for clearing that up, you saved me from making a very expensive mistake. I was cautious about listening to everyone say they are the same because after seeing that dana listed separate carriers for standard and reverse rotation, i knew there had to be a difference. Thanks for clearing that up.
-John
Old 08-05-2002, 07:44 AM
FordPerf300's Avatar
FordPerf300
FordPerf300 is offline
horsenamedcash
03-07-2015 08:21 PM
Bruners4
11-08-2014 11:48 AM
Livewire88
Offroad & 4x4
07-18-2006 01:34 PM
bossind
08-30-2005 10:49 AM
ClatonK
Offroad & 4x4
15
02-03-2004 12:59 AM
Quick Reply: Dana 44 trac loc question?
