Jeep Dana 44 Trac Lok in a Ford TTB Dana 44????
Originally posted by JeremyH
You dont want the trash lock that chrysler sells......not worth the time it takes to install it.
-Jason-
EDIT: BTW...I looked for you and I found a kit from Precision Gear http://www.precisiongear.com/cclip.htm
or try one of these:
http://www.reiderracing.com/c_clip.htm
http://www.wmsracing.com/pgi-ProductSpec?MOS-CELM
EDIT: Lol, ok i found this too ........."The brand new No Slip traction system provides the performance of a locker, with the QUIET operation that you demand for normal driving. This new system uses no friction clutch plates or cones, and does not require any special lubricants. Installation is also especially simple. It is designed to be installed by do-it-yourselfers.It simply replaces your open style differential. It smoothly transfers power from slipping wheels to the ones with traction. It works automatically, so you can keep your hands on the wheel - and your mind on the terrain. These are complete kits with clear & helpful installation instructions. Because your ring & pinion is not disturbed no gear lash adjustment is required" -http://www.appealingauto.com/noslip-90-93-dana-35-trac-lok---------92.html-
They put these in stock jeeps and they do not work at all. These units are know for their clutch plate failure in jeeps that are wheeled and are not much better than an open diff. If you want a limited slip.....go with Detroit Tru-Trac. It is a gear driven LS that doesnt require any LS additives.
Originally posted by ClatonK
Oh, Jeremy H this is a Trac Lok made by Dana Spicer not Jeep. They are the same guys that manufacture the Dana diffs for Ford, GM, Dodge ect.
Trust me on this one. I have had a jeep ever since I could drive and have heard nothing but complaints about this unit since Chrysler started using it in 1997 (note: this is one vehicles that are wheeled....not street queens).
I'd save your money and get a more reliable unit....like a lunchbox locker or a mini spool. These are much cheaper and have less parts that can fail.
As for the manufacturers you listed....GM uses Corporate axles and Dodge uses AAM.
Actually, GM and Dodge have used Dana 44s in some their trucks usually in front axle applications. And the unit I am talking about is a Track Lok that has been around for decades. The unit Jeremy is talking about has only been around since '97. We must be talking about differnt things. The track Lok is so reliable that the big 3 auto companys have been using them for decades. The clutch plates do wear out eventually but that does not cause a break down. With a mini spool or lunch box locker, you are far more likely to break an axle or eat up bearings which does cause a break down and will leave you stranded on the trail.
Clayton
Clayton
