the pcm tests good (no codes) without the chip and with a different chip. So it must be an issue with the chip - I know the 605 code = Internal Control Module ROM Error, but that is the extent of my understanding. Any thoughts?
Think he's gonna try testing with another PCM.......
I thought the ROM was the programming imprinted in the PCM (or chip). I don't really understand how all that works, but when the manual says clear codes and retest, if 0605 shows back up replace the PCM, then I figure that's not good news. If the PCM check out OK, then I'd suspect a chip or chip connection problem.
Looks like there is issues with his F5. Tried a different PCM, both PCMs test fine by themselves, stand alone - no chip. Install chip and he gets the P0605 error with both PCMs. Tried a different chip & tested it with both pcm's, no errors.
Thanks for the help Chris........at least the PCM isn't fried
