Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
how much area does an 80lb bag of concrete cover?
Old 08-10-2008, 10:40 PM
karljay's Avatar
karljay
karljay is offline
I'm building a new shed, I'm going to buy the 80 lb bags from Home Depot. The depth will be about 4" (using a 2x4). How much coverage will each bag give me?
Thanks, KarlJay.
Old 08-10-2008, 11:26 PM
1stoldtruck's Avatar
1stoldtruck
1stoldtruck is offline
Here's a calculator
The calculator at this site, Concrete Volume Calculator , will take your measurements and tell you how many bags (various sizes), cu ft or cu yards the job will require.
I ran a calc to find that 1 cu ft requires 1.7 80'lb bags....so one bag is about .6 cu ft.
Old 08-11-2008, 03:51 PM
jwtimme's Avatar
jwtimme
jwtimme is offline
more than you think it will, there is a chart on the side of the bag that will help you figure how many bags
Old 08-12-2008, 07:54 AM
mitchntx's Avatar
mitchntx
mitchntx is offline
Lay the bag down on the ground. That is about how much it will cover.
Old 08-12-2008, 05:29 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Using a 10x12 shed as a starting point, it will take you 67 bags. Also, if you simply lay 2x4s on the ground the concrete will just lift them up and flow under them, or bow/push them out of the way.
Last edited by Ford_Six; 08-13-2008 at 12:30 AM. Reason: Because I lack basic communication skills
Old 08-12-2008, 10:55 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
QUIKRETE® - Cement and Concrete Products has a materials calculator right on their website.
Steve
Old 08-20-2008, 04:57 PM
385seriesHemi's Avatar
385seriesHemi
385seriesHemi is offline
For the amount I wouldnt know so im assuming Ford_6 is correct for laying the slab. When buying 2x4s get the straightest ones possible. To prevent bowing of the boards (which berely ever happens on this small of a slab) put a stake every 2 feet or so on each board. Then get a draw string to go across the forms to put a stake or two in the central area of the slab for "grade stakes" so when you pour the concrete in the middle.
When you have reached the middle you will know what height (same height as 2x4s) to screet the mud to for being flat from those grade stakes. Screeting can be done with a NON bowed or warped board so you don't have dips in the concrete. If you already knew this I guess I just remided you of it but good luck.
Old 08-20-2008, 09:08 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
lots of bags
67 Bags? thats a lot of 80 lb bags to lug home from Home Depot. Check in theYellow Pages for concrete companies that will mix and deliver short loads on site.
Old 08-20-2008, 09:11 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
how much coverage per bag?
An 80lb bag yields 2/3 of a cubic ft per bag.
You will get 2 sq ft of coverage @ 4" thickness. Dont run out of bags in the middle of a pour!
Old 08-20-2008, 10:27 PM
DIESELPOWER5's Avatar
DIESELPOWER5
DIESELPOWER5 is offline
concrete
I have not used this one way that I think you are using is it what they call premixed? or pre made?? We dad used to buy the concrete in the bags and get, me to mix it with navajack a ( 3/4" minus, sand and gravel) He told me 4 to 1 was a good mix for gravel/ cement. If I was making concrete pipes I went 3 to 1 used to drive dad nuts. ( I do miss him) Don't use to much water in it for it will slump more that way. I wants to be just wet enought to shovel and for it to stay on the shovel. As for the gravel ( navajack) there would be amounts listed in loose materials for gravels that should be close the to volume that you need. Have you go a gravel sales company around you that could advise. I didn't read the volume that you had. 4" = 1/4 cu ft x width x length.. Will give you cubic feet. Sorry you probably know this but you can almost never over support/ brace concrete. Hope it works out for you it has been 30 yrs since last worked much concrete slabs.
Old 08-21-2008, 08:07 AM
385seriesHemi
If he goes to a ready-mix company it might be more expensive since there is a delivery fee most likely & the price of mud has gone up also. I think from what I remember on our last job, the company we used it was 300 bucks for 2 - 1/2 yards of mud. So if he has a big bin and two guys mixing with shovels I am sure it will go fine.
Old 08-31-2008, 08:24 PM
birdman1's Avatar
birdman1
birdman1 is offline
Like mitchntx said, the coverage is the same as the bag laid on the ground, you add water to it but it does not swell up, Naturally you can use the concrete calculator for large jobs, but I (at Lowe's) always tell folks it they are pouring a sidewalk or stepping stones the bag size is what it will be once mixed.
later, Mike
Old 09-04-2008, 05:33 PM
Talltruck's Avatar
Talltruck
Talltruck is offline
Also take a look in the phone book to see if there's a U-Cart company -- they have a small cart that carrys about 1 - 2 yards of concrete they've mixed, all you do is haul it to your house and dump it into your forms. The problem with mixing that much bag concrete is that the first bags you mix are drying by the time you're mixing the last bag unless you're fast.
karljay
29
01-24-2017 08:29 AM
karljay
06-21-2016 12:38 PM
karljay
08-29-2005 08:27 PM
karljay
27
01-13-2005 02:11 PM
karljay
15
11-21-2004 10:03 AM
Quick Reply: how much area does an 80lb bag of concrete cover?
