Trying to decide on a good towing cam with power for the street
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">Here is a Lunati cam I found at Summit:
Lunati 00053 - Lunati Hydraulic Flat Tappet Camshafts - summitracing.com
It has lots of duration (300) and a .514 lift. The pistons I am using are the speedpro H395P. I'm using stock 1975 heads and the block is a 1968 block. No deck work and the heads are totally stock so no mill work on them. I want to be sure the cam lift isn't too much for the pistons and will this be a good toque cam. The cam I got with my master engine kit seems a bit weak or as stated by someone, a stock setup cam. I will be running long tube headers and a stock 4V intake with a Holley 600 carb ( came with it originally).
</TD></TR></TBODY></TABLE>
If this isn't a good choice, what do you guys recommend with my setup without doing any changes to it.
getting there, but not quite
Sal, that'd be better than the stocker, but the ramps seem slow to me. That Lunati advertizes @ 300, but has 223 @ .050. Heres whats in one of mine, a Crane 343801. I don't know if Crane and Lunati use the same lift for advertizing, but this Crane advertizes @ .004 and alleges 278/290, with 222/232 @ .050, with .548 and .580 lift. I have this one in my 2wd and use it for daily driver stuff and pulling trailers full of firewood. I have a C6 with the stock '71 truck convertor behind it and a 3.5 axle gears with 33 inch rear tires. It has done very well for me. DinosaurFan, on work's old 'puter
OK I checked with Melling and they offer their RV cam with the following specs and I want to know if this is good and also what is out there that has the same or close to the same specs that might be a bit lower priced:
Brand: Melling
Product Line: Melling M-Select Torque Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Part Number: MEL-CL-MTF-4
Cam Style: Hydraulic flat tappet
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 292
Advertised Duration: 282 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.484 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.484 int./0.510 exh. lift
Lobe Separation (degrees): 107
Brand: Melling
Thats just about whats in my 352 to the # I have a .517 ex lift and 117 lobe sep IIRC. It's a nice torque cam for a low buck setup. Isnt much for over 5k but hell who's towing with those kinda R's going on? I'd strongly suggest getting all your engine parts mic'd and then leave your cam choice for last. Oregon cam grinders and a few others will custom grind a cam for you starting around 90.00 or so. Or you can pick from the litter... if you mic it all out you can grind to fit.
Brand: Melling
Brand: Melling
I am running that cam in my 428. Seems to work great. It was a recommendation from Barry Robotnik at Survival Motorsports.
Tim
Joks79
12-23-2008 11:46 AM
snooky1966
09-26-2008 10:24 PM
chuck123
08-06-2008 09:30 PM
