<HR style="COLOR: #ffffff; BACKGROUND-COLOR: #ffffff" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message --><!-- google_ad_section_start --><!-- In 1st Post Ad --><TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width="100%" itxtvisited="1">OK this has been happening when its cold. the driver side door won't close all the way unless I put all my force into it.Which from the inside is difficult. Is there any quick fix for this? And its only the drivers door.
Make sure he rear door is closed securely, and that it's latched at the top. I've always had trouble w/ the top of my rear door, that's the one that needs slammed, with your hand towards the top.
thanks tylus
i have 04 screw FX4
It's giving me trouble when outside temp single digits,other wise door shuts fine.
I will check the striker plate. And yes I have torx set, I wasn't sure how to adjust before.
If your door shuts fine at all times except when it gets very cold outside, adjusting the striker will probably not fix it and may cause other problems when the temperature warms up. You are probably having a problem with the latch assembly, possibly moisture freezing in it and causing poor operation at low temperatures. Does it shut fine after the truck has been driven and the heater has warmed it up? Dan.
that's why I asked if the door has always done this
another cause may be that the rubber has ice forming inside it and isn't compressing.
as y2k asked...does the problem still exist after she is warmed up?
Thats what is sounds like. Spray some WD-40 in the latch mechanism. Follow it up by lubing the latch with some lithium grease.
I have a similiar problem with my drivers door. I cannot tell you how many times I've had to pull over, get out, open the rear door, put my hand on the top part of the door, and slam it..........or its not completely closed and the first little bump you hit Is the adjuster on the top or bottom? thanks
I took my truck back to the dealer, because the top of the rear door wouldn’t latch without giving it a good slam, plus the driver’s door wasn’t aligned perfect. After they got done with it, the door is worse aligned, and the rear door still has to be slammed to get the top to latch, I was told by the service dept, and two salesmen that it’s a common problem.
This is the same problem I have with my '03 Explorer. When the temperature drops the doors won't latch until the vehicle cab warms up. Curiously this also seems to be a function of humidity as well - doesn't happen as often in extremely cold & dry weather.
I've sprayed the latch with no success - dealer says the latch needs replacing but it works fine when above zero - and I'm not up for replacing all latches unless convinced they're shot. Is taking the door apart for inspection and/or lube advisable?
Oh, for those with this problem... it might be worth your time to actually go to a body shop. They are the folks that understand lining up body panels, doors, etc. I bet they can tell if you what is screwing it up, and what you might have to adjust to get it working again.
Almost as common as salesman who will say anything to get a sale, or try to make a customer at ease with a "common problem".....
100% agree! Although “common problem” doesn’t exactly put me at ease. The conservation that I was having w/ the salesman, who is a friend of mine (sort of), was about the fact that I was looking to buy my wife an import, partially due to the out of box problems that I had w/ my new F150.
What I think the "common problem" is, is that the rear door may not get closed firmly enough, causing the top latch not to latch. I checked the passenger side and it latches with just a gentle push, where the drivers side needs a good slam w/ my hand placed towards the top to get the top to latch. I explained that to the service dept, but it's still that way. Guess my next trip will be to a good body shop.
