Regulator Screen
That's the reason I always say clean it from inside the bowl and don't take the FPR off. But never fear. Find a screen of similar mesh....i.e. a faucet screen in the house from the sink, or a screen from something you "may" find at a smoke shop etc. cut it to size around the plastic piece which can be removed from the FPR. ******But be careful, there is a plastic check ball behind it!!!!****** Once you have your new screen the size it needs to be heat up the screen glowing red with a lighter. Quickly stick it to the plastic piece and melt it together. You could use a flat blade screwdriver to push on it a little. That should take care of it. Hope that helps.
My truck did not have one when I got it. Had about 110k on it when I picked up on this. Truck seems fine.I think the screen is to help remove air from the fule. I got a pipe screen from a smoke shop. The silver ones are stainless steel and a real pain to cut to size so you might want to use the brass ones if you go this route. Thanks Rubber Duck for sending me the plastic ball I lost and goon luck Vinford.
Latter.......
Latter.......
http://rides.webshots.com/photo/2200...81788797PqDoLr
And also be careful with the o-ring.
here is another pic:
http://rides.webshots.com/photo/1080...39885334oZZrLL
Westcoastslider mentioned the O-Ring. I want to put emphasis on the 0-Ring Don't loose it or you will have
Big Leak.
You can get the OEM replacement kit fro the stealership for around $35.00 and you can rest assured that it won't be in stock and it will have to be ordered. A call to the International Dealer might be a better way to go if you have one close by.
Rog
Big Leak.
Rog
Big Leak.
Rog
Big Leak.
Rog
Fuel Pressure Regulator Screen Kit (Orifice Vent Kit) Includes screened plug, o-ring, check valve
(Ford) F6TZ-9150-AA Screen and o-ring kit
(Ford) F5TZ-9A214-A ??? KIT-VENT ASY -DUAL
(International) 1823658C91 (screen only, doesn’t fit the PSD!!!)
