Shift handle
Transmission Selector Lever - Floor Shift
Removal
<TABLE cellSpacing=0 cellPadding=0 border=1><TBODY><TR><TD></TD></TR></TBODY></TABLE>
Removal
- Remove the floor console left side kick panel.
- Lift the console storage lid cover and remove the console finish panel.
- Disconnect the transmission shift cable from the arm of the transmission floor shifter.
- Disconnect the transmission shift cable from the transmission shift cable bracket on the transmission floor shifter.
- Remove the transmission floor shifter screws.
- Disconnect the transmission floor shifter electrical connector and remove the shifter from the vehicle.
- Using a suitable tool, pry forward on the top of the selector lever button and remove the button.
- Remove the screw, slide the selector lever **** up and remove the ****.
- Remove the selector lever **** shroud.
- Disconnect the transmission control (TC) switch electrical connector and remove it from the selector lever housing.
- Remove the PRNDL bulb from the selector lever housing.
- Remove the screws and separate the top and bottom halves of the selector lever assembly
johnmel59
05-26-2014 02:00 PM
ford66
08-06-2009 10:54 AM
