Shift handle
Old Jul 6, 2008 | 02:45 PM
x79f100x's Avatar
x79f100x
Shift handle
I quickly bwosed the other pages and found nothing so i will start a new thread.
I have an 2005 f150 with a center console shifter.
Long story short, I need to replace the whole shift handle and dont have the slightest idea how.
Any help would be appreciated. Thanks.
Old Jul 6, 2008 | 03:27 PM
bridge's Avatar
bridge
Sick 'n Tired
Transmission Selector Lever - Floor Shift
Removal
<TABLE cellSpacing=0 cellPadding=0 border=1><TBODY><TR><TD></TD></TR></TBODY></TABLE>
  1. Remove the floor console left side kick panel.
  1. Lift the console storage lid cover and remove the console finish panel.
<!--var HIGHNONE = '';var LOWNONE = '';// --><TABLE cellSpacing=0 cellPadding=0 border=1><TBODY><TR><TD></TD></TR></TBODY></TABLE>
  1. Disconnect the transmission shift cable from the arm of the transmission floor shifter.
  1. Disconnect the transmission shift cable from the transmission shift cable bracket on the transmission floor shifter.
  1. Remove the transmission floor shifter screws.
  1. Disconnect the transmission floor shifter electrical connector and remove the shifter from the vehicle.
  1. Using a suitable tool, pry forward on the top of the selector lever button and remove the button.
  1. Remove the screw, slide the selector lever **** up and remove the ****.
  1. Remove the selector lever **** shroud.
  1. Disconnect the transmission control (TC) switch electrical connector and remove it from the selector lever housing.
  1. Remove the PRNDL bulb from the selector lever housing.
  1. Remove the screws and separate the top and bottom halves of the selector lever assembly
Old Jul 6, 2008 | 03:56 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Whats wrong with your old shifter I may be interested in buying it from you for parts
johnmel59
May 26, 2014 02:00 PM
twom7
May 28, 2013 12:09 AM
Nickiboy
Oct 30, 2009 01:41 PM
ford66
Aug 6, 2009 10:54 AM
Fordnite302
Jun 24, 2004 08:15 AM
