Decoding VIN
Decoding VIN
new to this process so i hope i don't step on anyone's toes.
just had towed to yard a '68 ford firetruck. have had no luck in finding out information using the VIN. local parts stores have no reference books and so far internet has been a zero. the VIN is N70DUD12735. it is stamped on a door plate, it is on the title and it is stamped on a plate attached to the Champion fire pump. any help in decoding the VIN would be appreciated.
have a great day!
have a great day!
Here is what I got from another website with your VIN number:
N70 = LN-700 (Gasoline) (That is the truck model)**
D = 330ci 2V HD V8**
U = Assembled in Louisville, KY
D12735 = Serial Number (puts at around April 1968 build)
N70 and D were not on that website (it's geared toward 1967 - 1972 pickups only) however I got the information out of my 1972 Shop manual and am assuming the information is the same.
Decoding Vin
Thanks NumberDummy
Since my last post spent good bit of time with search engines and found the following link:1968 Ford VIN
It reads like poetry. Also went on Gates Rubber site:The world's most trusted name in belts, hoses & hydraulics | Gates Corporation and they have VIN Locater which printed out 1968 Ford N Series V-8 330 and gave me all the replacement hoses and belts with the exception of 5/8 id coolant hose that goes from the water pump to the block. So far haven't been able to pin that hose down. Everyone has been helpful. In futrue may make note of my ups and down with alternator that may help someone out down the road.
Thanks again
beentook2
Thanks again
beentook2
N700's.
There's a member here named Michelle.
She completly restored one of these trucks, the photos are in her member gallery.
There's no by pass hose listed in the parts catalog for the 330 M/D engine.
If I remember correctly, the by pass hose on 330 M/D engines (same for 352/360/390's) is just a straight piece of 5/8" heater hose.
Just cut it from 5/8" heater hose stock.
The 330 H/D, 361/391 engines use a special curved by-pass hose.
Ford confusion: Very few parts interchange between the 330 M/D and H/D engines.
justincase876
07-06-2011 10:08 PM
Ford-2-the_core
03-24-2011 06:49 PM
