If the wiring harness has a connector under the vehicle at the rear bumper, then you can get an adapter kit that pluges in-between. Then you don't need to cut or tap other wires.
__________________
WV Chapter Member
2002 Escape (as fitter said "Wifes Ride")
1999 F250 4x4 SD Crew 7.3 "The Beast"
1999 Mercury Sable
1982 F250 4x4 Known as BullDog! wilh a 300 l6, Offy "C", Holley 390 CFM
1960 Austin Healy Sprite MK I (Bug-Eye)
