Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Tow light adapter?????
Old Oct 18, 2007 | 11:45 PM
shags1980's Avatar
shags1980
I own a 2005 Ford escape without tow package. I added an aftermarket tow hitch and purchased the piggy back cable from ford for the lighting. Ford told me there was an adapter behind the bumper and all i needed to do was plug in this cable and it would work. Well it didnt. There apparently is no power going to this adapter. I have called about 5 Ford dealerships and noone in their service departments has any clue what the hell I am talking about. I see alot of people have had this problem, did anyone cure it on a 2005. Will a HD flasher really solve my problem??? Can i buy that piece anywhere and install it myself instead of being had at a dealership where they want $76 for the flasher?
Old Oct 18, 2007 | 11:55 PM
tcesni's Avatar
tcesni
Who installed your hitch? I have had good experience with U-Haul centers when it comes to wiring and hitches.
Old Oct 19, 2007 | 08:56 AM
shags1980's Avatar
shags1980
I installed the hitch.
Old Oct 19, 2007 | 01:13 PM
tcesni's Avatar
tcesni
The last time I self-installed a hitch I went to U-Haul and had them take care of the wiring.
Old Oct 20, 2007 | 07:42 AM
abusch's Avatar
abusch
Not sure what you plugged your wiring harness into, but if it was the factory installed trailer wiring, you will also need to install a fuse in the panel. Check your owners manuel for the location. I had a complete system installed, including electric brake controller, and have had no problems.
Old Oct 20, 2007 | 02:52 PM
ericsmith32's Avatar
ericsmith32
You'll need the heavier relay. Cost me less than that at RockAuto.
Old Nov 25, 2007 | 04:12 PM
JForestZ34's Avatar
JForestZ34
Towing
If you have seperate turn signals with brake lights you need a modulite modulator for your trailer wiring.. There about $30. That's what I needed for my 07. I've had the same small wiring from the dealer and it was a was of money. Just get the wiring modulator.. Some even come with circuit protection too, the only hard part was running a power wire to the battery.. Just take the power wire and cable tie it to something along the bottem of the car something that doesn't get hot, I use the brake line and haven't had a problem.
James
jwm1959
Feb 5, 2015 08:34 AM
Plain Jane
Nov 21, 2012 12:42 PM
franklee86
Jun 17, 2012 09:23 AM
fordzrule
Electrical Systems/Wiring
Sep 6, 2003 10:52 PM
textruckr
Jun 29, 2002 02:41 PM
