Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-07-2008, 08:22 PM
redlightning93's Avatar
redlightning93 is starting off with a positive reputation.
Draining lube on a 9 inch diff
My 9 inch diff has lube the color of coffee with cream so need to drain and refill. Problem is there is no drain plug so looks like I will have to drop the third member (chunk) to get the oil out. If that is the case it means removing wheels, pulling axles, dropping the driveshaft and unbolting and removing the third member to drain the lube. Am I missing some short cut here or did Ford really design this assembly to discourage servicing it. Would I be able to accomplish this by removing the pinion and drain it that way?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-07-2008, 11:04 PM
Ford_Six's Avatar
Ford_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to behold
You probably could remove the pinion support to drain. I'd drill and weld in a drain in the bottom of the housing, since even with removing the center section you can't get all the fluid.
__________________
Jared
Quote:
Originally Posted by Pablo Picasso
"Computers are useless. They can only give you answers.
Pablo Picasso ."
FTE Guidelines
  #3 (permalink)
Old 06-07-2008, 11:18 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
PITA but can you use a suction set up with a length of tube into the diff?
You will have to waste so new lube to "flush" it out, but less $ than the gaskets etc doing it the dropout way.
  #4 (permalink)
Old 06-08-2008, 02:33 AM
PatsPOS is starting off with a positive reputation.
I've had no problems getting 100% of the old fluid out of a 9" housing...just takes patience and a lot of paper towels.
Now, as far as the notion that Ford would "discourage" servicing the differential...I'd take the convenience of the ability to remove the third member for gear swaps and other service on a workbench over the convenience of fluid changes. When you've pulled one 9" rear, you've pulled 'em all...and it just gets easier every time you do it.
Pat
__________________
'89 F-150 F14 4.9L (18.37 @ 73 MPH)
'91 Crown Vic P74 5.0L (18.09 @ 75 MPH)
'75 Gran Torino 7.5+L (14.04 @ 97 MPH)
  #5 (permalink)
Old 06-08-2008, 09:45 AM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
I go with the mity vac vacuum pump and suction it out if it's not leaking there is no
reason to disturb the seal. Just like said above suction out as much as you can and
then put some fresh in and turn the tire then suction that out, do a couple times
and then refill. I use the mity vacc for everything suction out all the brake fluid from
the MC before bleeding brakes that way fresh fluid is in the lines versus a mix of old
and new. Power steering fluid not leaking why crack a line?, I also pull out a few oz
to a quart of tranny fluid every oil change to keep fresh fluid in my auto trannies.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #6 (permalink)
Old 06-08-2008, 02:15 PM
Thanks guys for all the suggestions. I do have a Mity Vac style pump and think I will try that before opening up a non leaking diff. Thanks again!
  #7 (permalink)
Old 06-08-2008, 07:01 PM
northern 7.3 is starting off with a positive reputation.
easy removal of 3rd member....just takes a bit of time, its those pesky copper washers that get me.....i think they'd hold the 3rd member pretty well just by themselves.
  #8 (permalink)
Old 06-08-2008, 10:21 PM
Well, finally ended up pulling the pinion carrier and draining it thru the front. I used a vacuum pump to remove the oil from the rear of the housing that remained. I tried to drop the third member but just could not get it to turn loose. Yes, those copper washers are tough to get off without destroying them. Looks like I am going to need a pinion seal so now I can get it to the workbench and do it there instead of lying on my back. Oh, to have a lift to be able to stand up underneath and work. Thanks again guys for the help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
