od button ?
05-24-2008, 03:04 PM
on
od button ?
my od button is broke off on my column well the whole tip is pretty much broke off is there any way i can dissengage od or put it on my truck is always on od -i didnt know there was a button there till i rode in my buddys 96 lightning
05-24-2008, 03:57 PM
on
The trans is allway's OD engaged.
The button is to disengage the OD.
Its a momentary switch.
Bill
05-24-2008, 04:36 PM
on
i know my button is broke i was wonderin if i can cram somethin in there to disengage
05-24-2008, 04:46 PM
on
Just replace the assembly.
You really want the lamp to work to notify you in the event of a failure.
Bill
05-24-2008, 05:38 PM
on
what all would i have to replace just the shift column or the whole deal
05-24-2008, 05:49 PM
on
on
or, you can replace just the larger part on the end
05-24-2008, 05:52 PM
on
theres no wires or nothin hanging out of it how does that mechanism work is it electric or just a lever
05-24-2008, 06:25 PM
on
start twisting the end back and forth and pull it off. DONT twist around and around. just a lil back and forth. i believe it has a connector in there. you can get by with just the end being replaced if the wires arent broken down at the column
05-24-2008, 06:27 PM
on
i've never had one apart all the way, but i believe theres a connector. we had to replace the whole thing on our 02
05-25-2008, 02:46 PM
on
i think its broke at the bottom
jimwilsonmasonry
03-24-2009 10:17 PM
edmundo7
2004 - 2008 F150
02-12-2008 09:23 AM
psd tuner
03-12-2007 06:30 AM
AC-MAN
10-31-2006 08:11 PM
69ford99
1978 - 1996 Big Bronco
09-25-2006 01:07 PM
