Easy way to drain oil in 9 inch rear diff?
I would pull the rear housing either way, I would much rather know I was able to take a glance at the gears and inspect for any unusual wear and have a fresh RTV seal. IMO
I might be missing something here, but you said pull the axles apart, can't you just pull the rear diff cover nothing else?
Not on a 9" rear. Its a third member where the ring, pinion, carrier, etc all comes out of the housing as an assembly. Its not like a Dana 60 or Dana 44 or most other differentials.
Thanks for all of the feedback, everyone!
I tried using a suction gun but didn't have any luck. There's really no clearance between the ring gear and the side of the housing to get the tube down to the bottom of the diff. I also tried using the old siphon method, but that seemed like it would take way too long, not to mention it didn't taste so good.
So I came up with an interesting way to get most of the oil out easily. I have the truck up on jack stands and I noticed that if I spin the driveshaft, a little oil was coming out. So I started it up and put it in reverse and let the truck idle the oil out. Probably not the best way, but without being able to get the suction gun in there and not feeling like getting another mouthful of oil, it seemed like a decent idea.
The only possible bad side is that I'm not sure that I got all of the oil out, but I'll try to siphon it again and see if any more comes out.
Again, thanks for the feedback.
Well
i was told how foolish i was for doing this but..
i drilled a very small hole in the back bottom curve of the housing and put in a very small screw with a washer and put a little sealant on it.
in 1986
so far i have had not a problem one...
reason is that it gets submerged in water 55-60 times a year and i like to change fluid....a lot..
in 1986
"THere is a tool available called a suction gun. Looks like a grease gun without the pump handle. You can stick the hose into the fill hole and suck out the old oil. You will not get all of it by doing it this way, but it will be close enough to make the new oil new."
The Rcrawler
This is how you do that!
The Rcrawler
Suction gun sucks when it comes to gear oil. Biggest POS I have ever used. Had a 5ver of Red Tacky which I used in the diffs and t-case and it was a pain to fill the gun.
I would drill a hole on the side and either weld on a bung with a plug or use a self tapping oil pan plug with 1 of those washers that have a rubber seal. After all you'll probably have to drain it again.
The simple solution.
Hello Fellow Ford Fu?!ups, I'm included in that so don't get all up in arms. Was I the only one paying attention in Science class? Granted I had a fine teacher so I paid extremely close attention. But all you need is a jug couple air fittings and tubing. As week as an air compressor. It's called a Ventura Pump. And you can make one at home in less than 30mins.
This is the one I've used for awhile now.
Black hose goes into the differential thru the fill plug and you insert your air into a hole drilled into the other line. Pointing the air to blow out the open end of the house. A suction is created in the jug that will pull the oil right out. Hope this helps. SINCERELY YOUR LOCAL HILLBILLY EINSTEIN
The following users liked this post:
on
I like the home made version. But I broke down and bought one of these. I love it. Especially on a front diff on a Ford IFS front end.
https://www.tooldiscounter.com/produ...SABEgL1AvD_BwE
ERIC79XLT
07-29-2004 08:51 AM
MattsF350
01-26-2004 10:07 AM
GeneStoner
01-26-2003 11:17 AM
