Hey guys just wanted to know if anyone has used Royal Purple power steering fluid in their Super Dutys? I was going to flush out the factory stuff and fill it with Royal Purple.
O ya its for my 2005 Super Duty V10 4v4
~Gage~
The Ford spec fluid is Mercon ATF. Mine had something clear in it when I got it, I'm guessing standard hydraulic fluid. I flushed with Mercon and its noisier now. Next I'll go to synthetic Mercon and if that doesn't work better I'll try a synthetic PS fluid.
Originally Posted by orng1
I think I'll just use the PS fluid to play it safe. But thanks for saying what your running.
~Gage~
I'm using it and I don't notice any difference. To be honest, if I had to do it over again, or the next time I do change it I'll use whatever the manual calls for. I don't think it's worth the price you have to pay for it.
I believe my flush took less than 2 quarts, so 8 would be pretty close. However, $32 for qts of PS fluid or about $20 for 2 qts of ATF which is spec'd for the system. I think I bought 18-24 qts when I did my Trans flush, and had a couple of qts left over to use on the PS and reserve. Now, I have a qt in a box in my bed that can top off both my trans and PS.
There's instructions linked in the tech folder I think. Basically unhook the return line from the master cylinder, put on a clear hose which dumps in a container, with truck running crank wheel back and forth while pumping the breaks until reservoir is almost empty, fill with fluid, repeat until fluid dumping looks like new stuff.
