Diff. and front axle fluid change
Old Jun 14, 2010 | 01:47 PM
Headviking's Avatar
Headviking
Don't read my signature, I am inquiring about my buddies truck.
2001 F350, Lairet, CC. 4X4, 7.3L, Automatic trans., 175,000klm (110,000miles).
I thought is was about time to do some maintanance on his truck but this time do it ourselves. He has always had a local shop do his work but lately $$, has become an issue. So here we go, a couple of back yard mechanics, with a cooler full, will be starting the work this coming Sat. First a couple of questions. Any recommendations to rear diff. fluids and grade (my F250 takes 75w-140, royal purple). Front axle fluids (my F250 takes 75w-90, royal purple). Transfer case fluids (my f25 takes Synchromax, royal purple).
I am still trying to find out the fluid capacities of his truck.
Do his F350 basicly take the same fluid as mine? Don't want to cause more problem for him.
Any help anyone can offer or suggestion.
Thanks
Old Jun 14, 2010 | 01:49 PM
Headviking's Avatar
Headviking
Don't star at my Avatar too long you'll forget my questions.
Old Jun 14, 2010 | 02:04 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Ford now recommends 75w-140 in the front differential. I used Motorcraft synthetic in both front and rear. The transfer case takes the same fluid as the transmission.
Old Jun 14, 2010 | 02:42 PM
Ponyboychris's Avatar
Ponyboychris
Read this link: Welcome to guzzle's Front Differential Maintenance Web Page
But like Rick says, I think Ford now recommends 75w-140 in the front as well. The writeup says 75w-90.
Old Jun 14, 2010 | 03:05 PM
Headviking's Avatar
Headviking
Now guzzle's site says it's for a SRW f350. Is there a difference?
Old Jun 14, 2010 | 03:11 PM
miller_feed
Same for all.
Old Jun 14, 2010 | 03:12 PM
Ponyboychris
Is your buddy's truck a dullie?
Old Jun 14, 2010 | 03:18 PM
miller_feed
Good question.
Old Jun 14, 2010 | 03:20 PM
Ponyboychris
The reason why I asked is don't dullies have a different front axle? not sure if that makes any difference anyway.
Old Jun 14, 2010 | 03:23 PM
miller_feed
Yep, we have the Dana 60 up front and the Dana 80 out back. But the procedure is the same alone with the fluid to use.
Old Jun 14, 2010 | 03:27 PM
Headviking's Avatar
Headviking
Sorry should have put that in. Am I correct in thinking that you use 75w-140 front and rear? I was looking at Royal Purple. The rear is limited slip so a modifier is needed, but with RP oil it's already it it right?
Old Jun 14, 2010 | 03:41 PM
miller_feed
yep, 75w-140 front and rear. I think it should say on the bottle if it has the modifier or not. I think it does have it.
Old Jun 16, 2010 | 01:41 PM
Headviking's Avatar
Headviking
The manual says 75w-90 with 2.7 L of oil for the front and 74w-140 for the rear with 4.0 L of oil and the transfer case says to use Mercon ATF with 2.0 L of oil. Any recomedations to a better oil like maybe Royal Purple Synthetic.
Old Jun 16, 2010 | 02:05 PM
miller_feed
Well, if you don't believe me or the rest of the guys here, call your ford dealer and see what they say. There was a TSB about this, but I can't seem to find it right now.
Old Jun 17, 2010 | 11:53 PM
Headviking's Avatar
Headviking
It's not that I dont' believe you, it's I keep getting more then one answer to the same question.
