302 Oil Capacity
302 Oil Capacity
The 302 found in Broncos&pickups takes 5 quarts of oil if you don't change the oil filter.If you change the filter,too(which is always a wise idea...)then the refill capacity for the 302 is 6 quarts of oil.My Bronco has an aftermarket oilpan on it,so it takes 7 quarts with a filter change.I'd check to see if your friend's 302 has the stock pan on it,or an aftermarket one.
302 Oil Capacity
I was intending to ask this question too. I always thought it was 6 with the filter, but when I changed mine, I put 6 in with a filter and it showed one quart over (yes I did start it to fill the filter). Is my truck a 5 quart oddball? wrong dipstick?
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
302 Oil Capacity
My 94 302 owners manual states that the capacity is 5 qts. I have only changed once so far, oil and filter, and used the 5qt bottle of Mobil 1. Ran it for a few minutes and then let it set for a few. Exactly full. I don't think there is any way the filter is going to hold a quart by itself.
302 Oil Capacity
Haynes manual says 6, owners manual says 5 plus 1 for the filter. I get 5 with the filter. Says the same things for my '86, and it takes 6.
truebluehero
02-19-2017 01:38 AM
armyaviation
01-13-2017 09:41 AM
Lil' Bit
03-19-2016 11:27 PM
