1996 302 converting to 351W
Old 03-19-2016, 05:52 PM
Lil' Bit
Lil' Bit is offline
Lil' Bit is starting off with a positive reputation.
Will the intake on the 302 EFI work on a 351W with larger injectors? I am planning a rebuild of a good 351W to use in my 96 Supercab 4x4. The 302 is good with no oil use at 212,000miles, but this may change anytime, so I want to build a larger engine for the next twenty years.
Lil Bit
Old 03-19-2016, 06:18 PM
Motorhead351
Motorhead351 is offline
Motorhead351 is gaining momentum as a positive member of FTE.Motorhead351 is gaining momentum as a positive member of FTE.
The 351w block, is physically taller and wider than the 302.
That means the lower efi intakes, are different, ones wider than the other, they don't interchange.
The efi uppers on the regular 351w and 302 engines, are comprised of different port shapes, they don't interchange.
Old 03-19-2016, 07:11 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
You need a complete 5.8 EFI motor to do this swap and because they introduced some new sensors with the OBD2 system and because part of one of those systems(the EGR) is routed differently on the 5.8 you need a '96 5.8 motor. Very few parts will transfer from the 5.0 but the complete engine harness will plug right in and the motor will run fine without a PCM change after it has had a chance to adjust to the larger motor.
Old 03-19-2016, 11:27 PM
Lil' Bit
Lil' Bit is offline
Thanks to both of you. That is what I was afraid of. Great site and I am glad I joined.
Lil Bit
Lil' Bit
10-04-2017 05:37 PM
OCDRESTO
09-17-2017 06:10 PM
Cody Baker
Engine Swaps
11-14-2016 11:32 PM
Lil' Bit
07-17-2016 09:20 AM
Lil' Bit
23
04-06-2016 09:41 PM
Quick Reply: 1996 302 converting to 351W
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
