Front Oil Seal 86 302
[updated:LAST EDITED ON 18-May-02 AT 11:00 PM (EST)]Pilotrick,
I would assume, all new gaskets and seals were put on the newly rebuilt motor. If this is the case, and a new front seal was installed, the problem is not the seal, but a worn harmonic balancer.
You can buy a harmonic balancer repair sleave for probably less than 10 bucks.
The exact same thing happened to me. I rebuilt the 302 in my 83 bronco last fall, and everything ran great except I used a quart of oil every 500 miles. I found it to be coming around the front seal. An 18 year old kid at the parts store told me about the repair sleave. I wish I had known about this this trick before I assembled the engine. I can almost get to 3000 miles now before I am a quart low.
C.Davis
C.Davis
>Anybody know an easy way to replace the front seal? Motor
>less than a year old and front seal is puking oil.
>Rick
>86 302 EFI, bored 60 over, AOD,
>Headman Headers, Flowmaster 40 series,
>2 inch dual exhaust, MSD ignition
Well it was not the seal after all it was the oil pressure sending unit . It was puking out the end of the unit and dripping down the front cover making it look like the front seal. Speaking of the front seal I don't remember from when I rebuilt the motor, but can you replace it without removing the front cover :-X11 ? Chiltons says you can and Haynes says you can't which is right ? Thanks for your help
Rick
>Rick
Rick
