1997 f250 7.3 antifreeze puddle??????
Old 03-10-2008, 06:47 AM
jay42782's Avatar
jay42782
jay42782 is offline
hey guys,
aside my 78 f250 mud truck....i own a 1997 crew cab f250 7.3 powerstroke 220,000 and running strong.this is my daily driver.for about 2 weeks or so i have noticed my temp gage reaching alittle bit above normal,not alot but alittle.yesterday i pulled it out of the garage and found a 8"x8"thin layer of antifreeze.i inspected under the hood and under the truck only to find the frame alittle moist,but could not tell exaclty were it was coming from.the subframe was wet more towards the drivers side.my assumption would be waterpump but unsure.visually checking the pump appeared to be dry.this is my first deisel so any input would be great!! thanks!
Old 03-11-2008, 06:37 AM
Dukernc's Avatar
Dukernc
Dukernc is offline
Did you take a look under the truck at the very bottom of the water pump to see if weep hole at the bottom is wet? This is a sure sign of water pump failure. Good luck..
Old 03-11-2008, 10:34 AM
JOAT101's Avatar
JOAT101
JOAT101 is offline
i just did a waterpump on my '97 powerstroke last weekend. mine was leaking out of the weep hole and dripped right off of the center of the engine block so it was definately the pump.
if yours is a bit to the driver side, i would look at the tube between the pump and the lower hose. while you are driving, the fluid could be blown back to the crossmember. my pump came with a new one and good thing cuz the old one was darn near rusted through.....
Old 03-11-2008, 01:07 PM
jay42782's Avatar
jay42782
jay42782 is offline
i'll check it out........thanks guys!!
Old 03-11-2008, 01:10 PM
jay42782's Avatar
jay42782
jay42782 is offline
if it is my water pump.......do you guys think a pump from autozone,advance,oreiley's is acceptable.one of these would be more in my price range than a dealer but if you don't recomend it than i'll go to the dealer.thanks!
Old 03-11-2008, 01:20 PM
JOAT101's Avatar
JOAT101
JOAT101 is offline
it really shouldn't matter........
i think they are all made by the same manufacturer.
got mine on e-bay for about $100 including shipping.
Old 03-11-2008, 01:46 PM
jay42782's Avatar
jay42782
jay42782 is offline
cool......thanks i'll check em out!
Old 03-11-2008, 02:26 PM
ryaneverk2's Avatar
ryaneverk2
ryaneverk2 is offline
Moved to 7.3L PSD section.
Old 03-11-2008, 07:21 PM
jay42782's Avatar
jay42782
jay42782 is offline
thanks ryan!
Old 03-11-2008, 07:29 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
These guys already have you on track. If its the water pump normally it drips down right behind the crank pulley. The thermostat/upper rad hose housing leaking is common as well.
Old 03-11-2008, 09:46 PM
rgjrtxf250's Avatar
rgjrtxf250
rgjrtxf250 is offline
Leak at fuel filter canister
I have replaced the vacuum switch at the diesel fuel filter canister, but I still see diesel fill up at the intake manifold housing. I am a novice at owning a diesel but I have always wanted one and I am trying to learn as I go. I try to do most of the work because I want to but this one has me stumped. I seem to find a wet rubber hose that connects at the base of the fuel filter canister to the base of the fuel pump. My diesel is a '94 F350 C/C 2WD. Standard. Thanks, rgj.
Old 03-13-2008, 07:25 AM
rehassinc's Avatar
rehassinc
rehassinc is offline
Hello, if it is the pump try to buy a one piece pump with the suction neck cast into the pump instead of the two piece bolt on neck. It's just one less leak point. Good Luck----------
73f250cummins
General Automotive Discussion
01-28-2013 01:58 PM
banks0531
1999 to 2016 Super Duty
06-29-2012 03:23 PM
79F250RepoTruck
03-23-2012 08:37 AM
mickpowell1967
02-04-2012 08:27 PM
lifted77f250
15
08-28-2008 07:37 AM
Quick Reply: 1997 f250 7.3 antifreeze puddle??????
