performance 5.8 roller cam
You can bump the base timing up a few degrees, and that'll help and it's a free mod too.
Shorty headers will yield a slighty louder exhaust note with minor performance improvements. Most of these bolt-on pieces do not require any other exhaust modifications; just install it and go. Long tube headers will make a little more power, over shorties, and a louder exhaust note. However, some exhaust modifications are required to the mid-pipe section to accommodate LT's . You may also need to lengthen the O2 sensor harness as well....I had to do that with mine anyway.
