5.8 roller sd
Old Feb 29, 2016 | 05:58 PM
lil9er's Avatar
lil9er
5.8 roller sd
Will a 5.8 roller cam engine work with the 89 sd system? I know the specs are close to the same but didn't know if it was enough to make the ecm not work. the computer is for the 5.8 in the 89.
Old Feb 29, 2016 | 06:02 PM
Conanski's Avatar
Conanski
Yes no problem, but be sure to use the '89 distributor and put a steel drive gear on it before installing.
Old Feb 29, 2016 | 06:08 PM
lil9er's Avatar
lil9er
Thank you! I know the sd system don't take well to changes. Just wanted to check before I did the swap.
Old Feb 29, 2016 | 06:12 PM
Conanski's Avatar
Conanski
Oh.. you may have to put the '89 lower intake on the '95 because the IAT sensor was moved to the airbox in the '90. DO NOT use any wiring from the donor vehicle.
Old Feb 29, 2016 | 07:26 PM
lil9er's Avatar
lil9er
There is a plug in the middle of the lower intake that looks to be in the right area for the sensor.
Old Feb 29, 2016 | 09:50 PM
rla2005's Avatar
rla2005
Look closely, it is probably not threaded or drilled through.
r6bikerdave
Mar 23, 2017 04:21 PM
f1001969mike
1978 - 1996 Big Bronco
Apr 25, 2013 05:20 PM
StuntmanFyke
Sep 27, 2010 08:01 AM
sign_man
Dec 7, 2007 08:31 AM
loujam
Apr 17, 2004 05:26 PM
