Need Help with A4LD
I believe you can, that's just like asking if you can take a tranny off of a 2wd aero and use it in the 4wd, really all that's diff. is that output shaft (atleast w aeros.) some on here say that ranger/explorer/aero are the same? my neighbor has an explorer, but the motor is a 4.2l? iono check the bell housing bolt patterns, the bell housing may be diff. but the body could be the same, ummmmmmmmm.... oh yeah check the bolt pattern of the output shaft
hey could you please help me with my issue Asalvage I have a 89 Mustang with a 2.3L with the A4LD I was doing 40mph and lost power the engine runs perfect in park or neutral but in drive its top speed is 25mph and it takes afew to get there. Is this a transmission issue? Even on jack stands and in drive the engine is perfect. I have changed the fuel filter and fuel pump, the air filter, plugs and wires, cap and button, ignition module, and changed the torque converter today the issue got better after changing the torque converter but it still isnt right please help.
You may get better responses in the transmission forum, but I'll refer you to what I just told another guy asking about A4LD problems in his Aerostar:
https://www.ford-trucks.com/forums/2...l#post11073893
You need to rebuild you old one, swapping a trans off a Ranger or Explorer is way to much work. If you have to disassemble it anyway, save yourself some money and rebuild the old one. Rebuilds in my experience give more consistent longer lasting results that swapping in someone else's neglected piece of trash thats running on borrowed time. People having good luck with swaps is the exception, not the norm.
Rebuild the thing, thats my vote.
LTCPipkin
09-12-2011 09:08 PM
RangerRage
1983 - 2012 Ranger & B-Series
02-03-2000 04:49 PM
