Exhaust Question
Exhaust Question
Hey guys I've Got a 97 PSD which I am in the process of working on. Just added a banks intercooler, Diablo 3 position chip, 1.0 a/r housing, tranny module, 3"dp, 10k mod and shimmed fpr. Kinda running low on money for exhaust now so I left it withjust the dp dumping under the cab. Turbo spools up awsome with the housing and no back pressure, just want to know if this will hurt anything (besides my ears and vibratingthe entire cab when you step on it) if I run like this for a month or two. Thanks
I would be sure that you have a pyro after all those mods. If not get one now before anything else. I don't believe it will hurt but I wouldn't try it in the very cold temperatures, I am just funny that way. Welcome to FTE it looks like you have been bitten by the PMS bug already. Post often you will learn much here.
Yes, I do have gauges-boost, pyro,&tranny(forgot about those) With the cold weather issue, would that just be for warmup? Was thinking about wiring the ebpv for exhaust brake, but I think that I saw someone put it on a three position switch so you could use it still to warmup. I saw cOOn's plexi glass shield(great idea over some of those ridiculous covers) Maybe I should do that to helpwith temp?
The turn down would be to get the fumes down and out from under the truck. I wouldn't let it idle while still very long.
The thermo you can get here:
http://www.dieselsite.com/index.asp?...ROD&ProdID=186
Thanks guys. I'm new to the diesel scene. I have heard in diesels that with backpressure "less is more". Just didn't know if you could go to far. Question on the exhaust- I have some scrap pipe that i could get it to the front of the rear tire but I can't find the flange to bolt up to the dp. Would hate to tack it to the new dp for a temporary fix. Anyone know where to gett it. Dumb me didn't save the old one!
