98 F-250 7.3
Welcome to FTE. It will depend on the overall condition of the rest of the truck IMO. A good torque converter will cost more than $800 but the trans needs to be removed so it might be a good time to rebuild it. A good rebuild will cost $2K...so the total could excede $3K. The trannies are the weak link in a great drive train. A bullet proof trans is more than $5K. A cheap rebuild may be as little as $1500 but they usually don't last.
on
1 Post
Nope just recomfirmed what I thought I knew thanks. They made the LD250 up to 03? I did not know that I thought they dropped them earlier then that.
Originally Posted by 150ford
There are no 98 250s unless it was a gas model LD250. 97-03 bodystyle. Ford had the 97 250s OBS an in mid 98 made the new bodystyle superduties. But there were called the 99 models. No I hope I didnt get you confused there.
on
1 Post
98 F250
Originally Posted by jdecker88
A 98? I thought they didn't make a 98 F-250 diesel just the F-250 LDs, they just had the early 99s in 98 like they have done the 08s last year. 3000 dollars is a good deal you can get that out of a strong motor, but as stated it will cost a good bit of money to do the redo the tranny.
Thanks for all the input.
Yes the body style is like the '97 and I was thinking of offering $2,000 because he has had it for sale for awhile. It does look like the oil pan is leaking because undercarriage has oil all over. Could not see any spots under truck where it was parked.
Where is the best place to get a torque converter (and maybe tranny) for it and did they install more than one type of tranny in this year?
on
The tranny is an E4OD. here is a great site to get parts
http://www.racerxautomotive.com/
Welcome to FTE. If the motor runs at all that would be worth buying. Post here and you will be able to fix ANYTHING on the truck. I agree it is a '97 or older truck. One of the easiest way to check A towing truck is to look at the mileage. How many miles on it? You can look at the turbo, find where the leak is from etc, etc, etc. We will help you and you will be fine. Warning be careful of the PMS bug...
