Coolent loss
Coolent loss
Hi,
I have a 1992 F-150 with 181,000 plus miles on it. I replaced the radiator, water pump, clutch fan assembly, upper and lower hoses and the thermostat. Whenever I drive the truck around town I find that the coolent level has gone down almost to the top of the core in the radiator. Any ideas as to what may be causing this?
Ace
Ace
Coolent loss
Pressure test the cooling system when the engine is cold . Also look at the hose running from the radiator to the coolant recovery tank , Esp where it connects to the tank . If its leaking there the coolant can be hard to see because of all the places it can run before it ever hits the ground .
Grey Beard
09-07-2016 08:17 AM
