Drain plug on E4OD Converter??
Yes there is a drain plug. Remove the inspection grommet on the bellhousing and rotate the crank pulley by hand until you see it through the hole. You can also remove the fuel pump relay and have someone bump the ignition until it lines up.
If you drain the converter and the pain then it should take around 12-14 quarts of ATF. You should fill it up in small increments (3-4 quarts), and running the truck through the gears between fills, until around 12 quarts. Then start going quart by quart and checking the dipstick. There's a good write-up here:
https://www.ford-trucks.com/article/...nsmission.html
where do you get to this? when i did mine, i dropped the pan and didn't see much else other than the filter. seemed like i'd really have to dig in somewhere to get anything else out. pics, good explanation? i assume it after i take the pan off?
useless now that i'll already dropped the pan and filled it, but its good info for the future
Its on the bell housing Tom, FORWARD of the pan. You don't need to drop the pan to access it. There is a round rubber grommet about 2" in diameter, pull that out and you've got a direct view to your torque converter. Rotate her around a bit and you'll see the tiny drain plug. I'll take a picture when I get home.
Originally Posted by quicklook2
tomtoc, most of the fluid is in the convertor and if you did not drain it than you need to service your trans again.
pbrogan
09-10-2015 05:46 PM
justcruzin125
07-06-2015 09:56 PM
kjjr20
08-10-2014 05:08 PM
97 Expy
07-21-2002 02:18 PM
